  3. שאלה | משהוא ניסה לדבר עם אוצרות התורה?
מתוזמן נעוץ נעול הועבר נפתר כללי
90 פוסטים 16 כותבים 662 צפיות 12 עוקבים
    • ori bensimonO ori bensimon
      @shishko כתב:
      אז יאלה פתח איזה מאגר ותביא אליו את כל הספרים
      כוונתך? למה לי להוריד את זה למאגר חדש כשיש הכל בהיברו בוקס?
      @ori-bensimon כתב:
      @shishko כתב:
      לעשות עליהם OCR
      • סתם אחדס סתם אחד
        No Sweat of the Brow Copyright
        Work performed on a public domain item, known as sweat of the brow, does not result in a new copyright. This is the judgment of Project Gutenberg’s copyright lawyers, and is founded in a study of case law in the United States. This is founded in the notion of authorship, which is a prerequisite for a new copyright. Non-authorship activities do not create a new copyright.
        Some organizations erroneously claim a new copyright when they add value to a public domain item, such as to an old printed book. But despite the difficulty of the work involved, none of these activities result in new copyright restriction when performed on a public domain item:
        scanning and optical character recognition (OCR)
        proofreading and OCR error correction
        fixing spelling and typography, including substantial updates to spelling such as changing from American to British English
        adding markup (HTML, XML, TeX, etc.)
        digitizing, cropping, color-adjusting or other modifications to images
        addition of trivial new content, such as images to indicate page breaks in an HTML file, or pictures of gothic letters for the first letter in a chapter, or adding or removing a few words per chapter
        substantial reorganization, such as moving footnotes to end-notes, or changing the locations of pictures within the text
        recoding to new character sets, such as Unicode, or new formats, such as PDF
        There is some value-added content that DOES get a new copyright, but only for the actual new work (that is, it may be possible to remove the new copyrighted content to go back to a public domain document):
        translation into another human language
        creating a new compilation of existing materials (though the individual items compiled retain their public domain status)
        creating new original art work
        creating an original derivative work, such as an audio performance, a new chapter, or a set of favorite quotations
        adding a new introduction or critical essay
        Project Gutenberg is able to utilize any material which is judged to be public domain in the country of use (i.e., the United States). If it is determined that components of an item are public domain, but others are not, then the copyrighted components may be removed without the permission of whoever owns the copyright for the new content.
        It is Project Gutenberg’s practice to seek permission of those who distribute materials, including copyright claimants, before harvesting their materials. This is done in order to be polite, and to allow the producer or distributor to request a particular credit be used. But if permission is not given, public domain items can still be used by Project Gutenberg, typically without any attribution. Because Project Gutenberg receives submissions from many different sources, it is not always clear where an item came from. Volunteers who submit content they did not themselves generate should be diligent about reporting sources, even if the source will not be credited in the item as distributed by Project Gutenberg.
        @סתם-אחד כתב:
        כמובן שזה הטיעון, תמיד...
          כמובן, שהדיון הזה הוא למטרות שעשוע בלבד - אך אחד לא יקח כאן אחריות.
          E תגובה 1 תגובה אחרונה
            @י.-פל. וכוונתך? אם מישהו יבדוק לעומק עם עו"ד? לא מקובל עליך? או שלא נראה לך שמישהו באמת יתקדם עם זה? דוד שלי עו"ד ויש לי חבר משפחה עו"ד ואני דווקא התכוונתי לדון איתם על הנושא ברצינות
            נ.ב. מקסימום זה יכנס לתוסף של @יאיר-דניאל או לתוסף PDFים שלי שאני רוצה להוציא מתי שהו רק רוצה לבדוק את הנושא ההלכתי ממש לעומק כי מדובר גם על הוצאות רציניות כמו קוק וכדו'
            Y י. פל.י 2 תגובות תגובה אחרונה
            • E eli8565
              Y
              Y
              ymp's
              @eli8565 כתב:
              כבר נאמר כאן בשרשור שאם מישהו לוקח אחריות מלאה על הנושא נשמח מאוד שיכנס
              אם אתה בעניין נוכל לדון על זה באישי
              • E eli8565
                @eli8565 כתב:
                חוו״ד רשמית של עו״ד - אני מקבל.
                אם כבר, פנה אלי בפרטי, אני צריך לעוד משהו.
                • E eli8565
                  @יום-חדש-מתחיל בוקר טוב! תגובתך להנ"ל אם אפשר
                  #87
                  @eli8565 כתב:
                  אין לי מה לומר. הכל ברור וידוע לכולם. יש הקלטה, ויש את מה שאמרו לנו באופן אישי.
                  אנו [כלומר 'אוצריא'] לא יכולים לעשות כלום.
                  כל אחד אחר יכול לעשות מה שהוא רוצה.
                  מכאן ואילך, מה בדיוק אתה רוצה מאיתנו?
                  שכל אחד יקח את הדברים ויעשה כפי שהוא חושב ומבין.
                  מה שאני מבין מהדברים הוא, שכל אחד (שאינו נקרא 'אוצריא') יכול לקחת ספרים ולעשות עליהם OCR.
                  זהו.
                  עריכה: יש בדברי הבעלים הגבלה נוספת, שדווקא על ספרים ספציפיים ולא על כמויות. תוכלו לראות את התמלול המדוייק בהודעה הרב @חנניה כאן
                  יאיר דניאלי E 2 תגובות תגובה אחרונה
                    @eli8565 כתב:
                    זהו.
                    @eli8565 כתב:
                    זהו.
                    זו בדיוק השאלה, למה זה מובן כך, למה אוצריא לא תוכל לקחת את זה ממשתמש שיפתח הוצאה לאור/תוכל להשתמש בעצמה מאחר שאין כזו הגבלה חוקית - מותר לשימוש מסחרי, אסור להפצה ציבורית חינמית... כך לכה"פ לטענת כמה ניקים פה.
                    זה תמצית הדיון.
                      @eli8565 כתב:
                      זהו.
                      @יום-חדש-מתחיל מי אמר לך? הבעלים/מזכיר?
                      נ.ב. אולי אחרי העו"ד זה לא ינפק"מ
                        לא קראתי את 20+ ההודעות האחרונות.
                        אני חושב שהדיון חסר תועלת ותוחלת.
                        היה פה מישהו שאמר שינסה להוציא מכתב מעו״ד.
                        הלוואי שיצא מזה משהו (ושיפנה אלי בפרטי!)
                        לע״ע אין תועלת בהמשך.
                        • י. פל.י י. פל. נעל נושא זה
                        • E eli8565 סימן נושא זה כנפתר
